1993 Bighorn: console lamp for A/T shift position
1993 Bighorn: I have failed to discover how to get at the A/T shift lever illumination lamp on the console. I have removed the front console and got the black square plastic box thing to slide up and down the shift lever. But I can't see how to get at the bulb inside the box thing. All I did was break one plastic tab. I also can't see how to remove the top of the shift lever, and I'm also a bit frightened to do that in case springs and things fly out from the button mechanism that are hard to put back together again. Any help most welcome on this seemingly trivial task.
