Commy gearbox problems
muddyplumber
- Spring Free
Just been on godley trip n took the zuk,another problem happened on the way home.have a vn motor n auto box n it now doesn't seem to change into top gear....has got plenty of oil in trans...does anyone no what could be going on?is it time to biff it out?and do I have to find another vn box or will something like a vl box fit up to it.thanks Rich
muddyplumber
- Spring Free
Re: Commy gearbox problems
Pick Apart has just come to chch found a gear box 60bucks
( just gotta get it out) vs $480+gst
where are pick a part in chch
muddyplumber
- Spring Free
Halswell junction road,Hornby end,can't miss the massive yellow guy holding a spanner
- tomsoffroad
- Flopsie
We've had 2 Vn autos do exactly the same thing in the Navara. Binned em
I think possibly the Navara needs a bigger cooler which is happening at the moment as we are installing a whole new cooling system on it
muddyplumber
- Spring Free
Hey Tom yea your right about the cooling system,may have to look at adding in a fan of some kind as when I got stuck on the godley trip I could hear the trans fluid boiling which probley didn't help the gearbox much
got new box now just gotta fit in.
Rich
Rich
pruggerdore
my vn trans in hilux gets hot wont change up. only happens when the trans cooler fan stops
muddyplumber
- Spring Free
Hey mate,Are you running a small separate fan on the trans cooler that just runs off a switch?
pruggerdore
My setup, radiator on back with large fan setup on backside of radiator sucking thru radiator set on a thermal switch so dosnt run all the time. on front of radiator a smallsh fan runs full time pushing air thru radiator providing enough cooling for light running conditions. now on the air drawing side of the smaller fan I have my trans cooler so it gets a small amount of air flow over it all the time. works well.
pruggerdore
fans either need there own thermal switch or run as soon as you turn ignition on. if you have to manually switch on sooner or later your going to forget. But its ok the exploding radiator usualy reminds people lol
