I have a 94 Prado, when I first brought it I tried on some 15 inch rims but they didnt fit over the callipers from memory so I went with 16's. Ive noticed a lot around with 15's now. Does anybody know what offset the rims are or have the callipers been taken to with a grinder?
Thanks
Nick
KZJ 71 Rims
Re: KZJ 71 Rims
my LJ78 is running 15x8 -40 rims apparently.
mm of clearance on the caliper.
http://www.offroadexpress.co.nz/Forums/ ... im&start=0
Re: KZJ 71 Rims
there are some smaller 15" rims out there.
standard terrano rims wont fit onto a safari, both calipers and center wont fit over hub.
inside measurement of terrano rim is 13", where as standard safari rims have 14". they are both 15" rims, terrano are 7" wide, and dont know what width the safari ones are.
im pretty sure the steel white spoke rims ya can get are same as the safari ones too.
- jonossiksilvia
Re: KZJ 71 Rims
Smurf wrote:my LJ78 is running 115x8 -40 rims apparently.
how much you paying for those tires smurf?
Re: KZJ 71 Rims
jonossiksilvia wrote:Smurf wrote:my LJ78 is running 15x8 -40 rims apparently.
Er.
Feck I wish...
Re: KZJ 71 Rims
15x7 -22 I'm pretty sure are factory wheels off my KZJ78
Re: KZJ 71 Rims
My factory rims are 15x7 -19 (or -20 I forget)
