On Board Air Conversion of a TJ's Factory A/C System
TJ
Post by TJ »
This is the best write up I have seen for this on a Jeep TJ using factory compressor. One day when the a/c is dead, it might be an option:
http://www.jeepforum.com/forum/f9/board-air-conversion-stock-tj-c-system-full-write-up-pictures-1382701/
NZJeep
Re: On Board Air Conversion of a TJ's Factory A/C System
Post by NZJeep »
Well worth it.
Didn't read the whole article but have done a similar install in mine. Although mine didn't come with A/C the compressor I bought bolted up to the factory mount at the top (in place of idler).
Did mine slightly different in that I didn't install an oiler as I modified the internals and filled with grease.
Used a 160PSI pressure switch with air tank underneath and air couplings at each end of the truck.
Also have a regulated fitting under the bonnet for using air tools (at around 100PSI), etc.
TJ
Post by TJ »
Great, do you have some photos of how it looks.
Return to “Jeep”
