1kz into ln106
smiddy101
1kz into ln106
Post by smiddy101 »
whos the people to see regarding getting the engine mounted?
in the south island, i just want the engine mounts done, ill do the rest
andrew007
Re: 1kz into ln106
Post by andrew007 »
toms off road,hes on this site :mrgreen:
surf lux
Re: 1kz into ln106
Post by surf lux »
Any engineering place/automotive workshop would be able to do it as it's piss easy just cut the old ones off move back a few mm on each side and weld them on again. Also just make sure
that whoever does the welding is a certified welder and get proof.
Otherwise you might run into problems when you go to get it certed, thats if
it's going to be used on the road.
bob_or_jim
Re: 1kz into ln106
Post by bob_or_jim »
surf lux wrote:Any engineering place/automotive workshop would be able to do it as it's piss easy just cut the old ones off move back a few mm on each side and weld them on again. Also just make sure
Dont worry about the certified welder bit mate, competent and to a tradesman like standard comes to mind. Long story short is anyone can do it as long as they do a good job.
surf lux
Re: 1kz into ln106
Post by surf lux »
That's what I thought until I did them myself to a good standard
then took it for cert and they wouldn't have a bar of it unless I could
prove the person who did them was qualified. Very big hassle and alot of running around to finally get them to pass it. Went back to the cert guy 3 times, but I guess just like anything it all depends who you are dealing with,no doubt some cert guy's are alot more lenient and willing to turn a blind eye than others.
smiddy101
Re: 1kz into ln106
Post by smiddy101 »
I have been in touch with Tom and he has given me a price, very quick responce - good customer service
