Hi
I have been trying to find a noise in the front end of my truck. I unbolted the rear of one arm and found that I could move the arm up and down with a definite noise there.
I then took out all 3 bolts and found the rear of the two bolts into the diff is worn.
Has any one had this problem?
Where would I get these?
Are the front 2 bushes the same size as the rear bushes?
Thanks Henry
KZJ78 Front Radius Arm bolts and bushes
Re: KZJ78 Front Radius Arm bolts and bushes
Henry wrote:Hi
Thanks Henry
Yup radius arm bushes failing are common.
PM suzolla he sells factory bushes... Don't get aftermarket.. they flog out quickly.
From memory they are the same...
