My d21 terrano
For all Nissan related topics
Camfitz30
My d21 terrano
Post by Camfitz30 »
Started the mods the my terrano today, Manual locking hubs and new 15x8 rims with kuhmo KL71 31x10.5xr15. And have still got a body lift and snorkel to install this week. I might have to beef up the front end I think....? Post a few photos of you nissans to get some more ideas!
Image[/url]
Image[/url]
Image[/url]
ChurchurDan
Re: My d21 terrano
Post by ChurchurDan »
You shouldn't need a body lift to clear the 31's, then you wont need a cert.
Search 2wd mod for the steering and get an idler arm brace.
Dirtydog
Re: My d21 terrano
Post by Dirtydog »
definitly do the idler arm brace, even if you dont do anything else.
And in terms of the body lift i would only be doing it if necessary to clear tyres, you get a higher Center of gravity, and have to pay 500 bucks to get it legal. id be saving it for when you do a few things at once like bigger tyres, front modifications (if you do anything major) etc, its alot of messing around for no real gain.
What would be worthwhile however is a diff drop, and a lift, as you get a fair amount of clearance out of terrano's when theyre lifted up (thank nissan for desgning them the way they are :D )
Nice looking truck though,
retep130
Re: My d21 terrano
Post by retep130 »
can you put up some bigger pics showing off the new tyres? I was also considering KL71's so would be cool to see them
Bonus
Re: My d21 terrano
Post by Bonus »
Heres mine on 31" KL71's :D
lax2wlg
Re: My d21 terrano
Post by lax2wlg »
Dirtydog wrote:definitly do the idler arm brace, even if you dont do anything else.
Good call. Idler brace + 31"s + sensible driving, shouldn't have any dramas.
(Sensible as in not getting one wheel wedged in a rock on full lock and then flooring it)
Cool truck!
Camfitz30
Re: My d21 terrano
Post by Camfitz30 »
I will post some more photos after I fit my snorkel tomorrow night! I have body lift which I'm thinking of putting in this weekend... Should I give it a miss?
Camfitz30
Re: My d21 terrano
Post by Camfitz30 »
Bonus wrote:Heres mine on 31" KL71's :D
What mods have you done to this? Nice looking truck 8)
Bonus
Re: My d21 terrano
Post by Bonus »
Not a massive amount, just 2" suspension lift, tyres,rims, EGR Delete, boost increase. Looking at intercooling next :D
Camfitz30
Re: My d21 terrano
Post by Camfitz30 »
Did you need cert for suspension lift?
Bonus
Re: My d21 terrano
Post by Bonus »
No you dont
Dirtydog
Re: My d21 terrano
Post by Dirtydog »
aslong as the springs are captive throughout the range of movement, and there is no modification of the factory mounts you do not need cert.
spring keeping attachments apparently need a cert (from the lvvta website)
You do need a cert if you decide to go for a bodylift however.
Camfitz30
Re: My d21 terrano
Post by Camfitz30 »
Oh that is interesting, I did not know that you could run a suspension lift without a cert, I have a body lift kit ready to put in my truck but I'm abit relucklant to because of the price of a cert... So i was thinking maybe a suspension lift is the way to go? Thoughts on that?
will i am
Re: My d21 terrano
Post by will i am »
i had 2inch lift springs in the back off mine and just wound up the torisions for the front, looked the part on 31s
another d21 terrano
ex lancer build
philip121
Re: My d21 terrano
Post by philip121 »
what do CERTS cost like a lift Cert any other Cert cost if anyone knows would be interesting nice to know before you do a build
retep130
Re: My d21 terrano
Post by retep130 »
cert cost is a generic $500, I dont know what it cost for a recert though
Camfitz30
Re: My d21 terrano
Post by Camfitz30 »
Yeah I found that out. 450 smackers!
lax2wlg
Re: My d21 terrano
Post by lax2wlg »
If you're using it properly off road, You'll easily spend the cost of a cert on broken steering bits and upper balljoints & CV boots if you just twist it up 2" on the cheap. And the alignment will be all horrible..Plus Watch the way a worn out IFS truck behaves off road, tyres cambering in and out and deflecting all over the place.. horrible.
Whereas a bodylift keeps the relative COG lower, more crawl space, and you don't touch the front suspension. Plus working under the truck becomes SO much easier.
My opinion.... Get a fresh WOF and throw the bodylift in, you've already bought it, inexpensive idler brace, and you're away. Then take it out and get some good use out of it, eventually a tie rod will fail, then look at steering upgrades.
Technically you dont need a bodylift or a susp lift to run 31's...
