Landcruiser 70 pto
Landcruiser 70 pto
Hi guys I'm trying to find a ( pin I think ?) that attachs the lever on the winch to push to Ingage or pull to disengage what I would calla a key on to the drum it's the on the left of the winch. Have tryed reckers with no luck any ideas where to try ?
Re: Landcruiser 70 pto
I think I know what you mean.. I made my last two and tack welded them in to stop em falling out.
They are the two pins that go into the slot on the ring....?
Item 38201B two of them toyota P/N 90241-08009
That's the one mate you have the nob then across 100mm across towords the drum there is another pin and then the lever goes about 50mm towords the grill witch is where the pin lives to move the key back and forwards are both these pins the same ?
I wish I had welded them on.
Thanks heaps mate
