diff change for manual hiace super custom...??
jo-c-fus
Stropper
Post by jo-c-fus »
hi everyone, new to this site after searching up for some info on my "95" Toyota hiace/manual supercustom. Although tho it is a rwd and not 4wd, I have still joined this forum due to its awesome info and guidance...
I am wanting to no if anyone knows of any direct diff replacements I can use to slip into my van, as its seems abit revy on 3000rpm @ 100kms....(I thought I may have been a lot lower considering its a rare manual...?) if I could some how find a diff to make it drop to 2500ish rpm, I would be very stoaked! ... ... :wink:
many thanks in advance for the info :D
ohhh an also I have just installed a new 1kzte motor into my van, and have blocked the EGR with a blanking pipe after hearing its a good thing to do, with much gruntyer responce I may add.. was just wondering what I could safley put through the motor to clear out all the old soot/exhaust muck that has previously gone through it befor I may'd the upgrade.... many thanks once again 8)
BlakeNZ
Re: diff change for manual hiace super custom...??
Post by BlakeNZ »
look on the manufacturers metal tag, and tell us the diff code.
Does it have a straight/solid rear axle, or is it IRS(independent rear suspension)?
The Hiace Granvia and regulus have IRS, but I'm not sure about the super custom.
jo-c-fus
Stropper
Post by jo-c-fus »
IRS after looking at a pick of it up on the hoist,
BlakeNZ
Post by BlakeNZ »
well it will be a simple swap for you, as the hilux /hiace diff heads are interchangeable and there are plenty of ratios to choose from.
Where are you located?
What ratio diff do you currently have?
jo-c-fus
Stropper
Post by jo-c-fus »
sorry, has irs,have edited above post, I will give the van a good check over for diff ratio's etc and other usefull numbers.. cheers
BlakeNZ
Post by BlakeNZ »
ok, your range of choices is more limited now seeing that it is IRS. The hilux centre will not fit. apparently a toyoa altezza diff will fit. But not sure of ratios.
sig
Jeep Jeep
Post by sig »
are you sure its irs and not the coil solid axle ! .have had a couple of super customs 2wd and 4wd and they have all been solid axle.Didn't think any hiace based vechicle had irs rear
tweake
Post by tweake »
the super custom is just the top spec flashy version of the hiace van.
will still be solid rear axle so easy enough to swap diffs around. i don't know if its a 4cyl or v6 diff tho. with a 1kz i would think its v6 type. axle code on the firewall will tell you.
the Granvia is a people mover, totally different body than the hiace.
for cleaning crap out of the intake pull the intake out and scrub it out.
