I got a big trip coming up on Monday (Southern Safari), and I have noticed the tappet cover gasket appears to be leaking quite badly nearest the firewall. I have tweaked the bolts a tad but this hasn't helped.
I will now replace the gasket, but where would you recommend I get one from here in Christchurch? Ripco quoted me $65.00
After your thoughts gents
NB; yes I have a QD 32 but the tappet cover and block is the same as the TD27.
Ok people, move along. Nothing to see here. Thank you, move along. Ph 0212078472
