Has anyone got Holden 308 or 350 chev sitting round, after one for my HQ.
Cheers Rich
Wanted 308 or 350
- Spring Free
Wanted 308 or 350
Re: Wanted 308 or 350
Best bets probably getting a 350 smogger off that v8 joint in chch, take all the injection emmisions shit off, throw a manifold carb combo at it.
I do, but in taranaki
1 original bore 4.00" 308 1972 era that I freshend a few years ago tri pattern
1 +30 308 probably rope seal turbo pattern, heads off was a solid runner
1 +60 sitting in a VL, decent cam, probably done less than 10000km on rebuild(tri pattern) have trimatic as well but it seems to flare a bit going into 2nd, not sure.
But you should probably still go with a chev
x2 on the 350 mate there pretty old long in the tooth donkeys but there's shitloads of them out there still climbing out of the woodwork and plenty of old parts, new parts and any parts you want for them and all pretty cheep
and if you don't want to go cheep theres plenty of $$$ bits out there for them as well
if you want to go holden go find one of those injected 304 engines and shove a rear bowl sump and pickup off a 308 on it and drop it in they go pretty good
they are usually a bit under rated so nobody wants to use them, their loss your gain
what you want for the turbo pattern one Marty?
cheers Jase
cheers Jase
Probably $300 would be as low as id go, I have a new set of ARP bolts that I would recommend to go with it, but $300 as pretty much a long block. Just need to put the heads on get a dizzy and carb( I have some stuff lying around) and a starter and shes a good un
sweet as i'll grab that,
be down in a fortnight if that suits,
after a runner so will bring some extra cash to get us there.
- Spring Free
