hilux steering box
Dan
Stropper
hilux steering box
Post by Dan »
Ok so thinking i cld save $$ by doin th repair myself seems i was wrong. i had a leaky input shaft seal on power steer box an thought swt jst pull that bit out an replace seal job done. not so. iv managed to pull th worm drive out of th piston an now I'm completely bonkers trying to figure out how th hell it goes back together. anyone offer any links or advice??
00falcon
Re: hilux steering box
Post by 00falcon »
Dunno about your Hilux...
But i thought about doing the same on my Jeeps steering box when it was leaking from both the input and output shafts...
I was going to follow this video...
As simple yet f'ning complected as it looks...
https://www.youtube.com/watch?v=661ov4GIXAA
In the end, i bought a new box, that was only leaking from the output... and that seal was simple... no need to remove the innards...
Goggling Hilux Steering box pictures... yours seams somewhat similar...
but its anyones guess...
O[][][][][][][]O
Eat, Sleep, Jeep...
www.nzjeepclub.co.nz
nzlux
Post by nzlux »
I had a leaking steering box on my LN106 hilux, there are a couple (maybe more) videos on youtube about how to pull the steering box apart, replace the seals and then put it back together.
After watching a couple of youtube videos I took my steering box to a shop and got them to fix it.
Being 25 years old the steering box not only needed new seals but also for the shaft to be rebuilt due to corrosion
Mehrts
Post by Mehrts »
I've had a crack at replacing the input seal on a Hilux box and managed to get to the same point as yourself. There's a bearing retainer plate which was impossible to undo..
In the end I just replaced the box with another one. Seems to be all good now.
Toyhatsu Bitsalux
NJV6
Post by NJV6 »
Ha ha, add me to the list of pulled it all apart then couldn't get it back together so bought a second hand one! Dam ball bearings everywhere!
Smurf
Post by Smurf »
NJV6 wrote:Ha ha, add me to the list of pulled it all apart then couldn't get it back together so bought a second hand one! Dam ball bearings everywhere!
Same here, it is probably still on the shelf somewhere...
klompy
Post by klompy »
Remove the curved tin plates held in by 2 screws and they all go back in there, you have to rock the shaft back and forth and push them down with a punch. The last few sit in the plates with some grease, just make sure there all in there if not buy some more from a bearing shop.
Dan
Stropper
Post by Dan »
Klompy, is th tin plates ur talkin about on th piston?? i havnt pulled that out yet. hope its that easy. youtube was a little help altho i still can't find a repacking ballscrew vid for th hilux.
klompy
Post by klompy »
Yep there on the piston it will have to come out, remove the output shaft and it will just slide out.
Dan
Stropper
Post by Dan »
Many many thanks!! got it all back together last nyt. Nowhere as hard as i thought.
antsarooney
Post by antsarooney »
Same with me managed to get all the bearings back in but then broke the plastic ring then tried putting the old one back in and broke that to. Ended up buying another one.
