front driveshaft for the mu
I think the sleeve goes to the top from memory but it shouldn't affect the operation... just make sure you have the UJs aligned (if you've slipped the slip-joint apart) otherwise you could end up with driveline vibration.
It always pays (as I'm sure you've figured out by now
) to mark everything with a white marker before you start pulling it apart...
Steve
Steve
- mud_slinger
