Suzuki auto options
For all Suzuki related topics
NuSkewdy
Suzuki auto options
Post by NuSkewdy »
Hi Guys, do you know what models of auto's there are and how interchangeable they are?
i.e. 3 speed auto, 3 speed with O/D, 4 speed etc..
Also, on the suzuki automatics, the gear-locking thing on the gear lever doesn't work. Meaning you can select any gear incl Reverse and Park while the car is sitting still - or driving! Hmm...
Any idea how the gear-selection lock thing works - it has a button on the side but doesn't seem to do anything :? . Is there a quick check&fix I can do to make it safe(r) ?
NuSkewdy
Post by NuSkewdy »
Yeah... Sorted the gear lever thing. The screw that holds the hand-hold lever was screwed in too far. Hmm.. simple fix. But would like to know about the auto models and which ones could be swapped over..
Join up and put a post up on the NZ Suzuki Forum.....loads of Zookheads with information on there......
http://autos.groups.yahoo.com/group/nzook/
vando
Post by vando »
I'm guessing you mean for a Vitara/Escudo? The two options are 3 speed and 4 speed o/drive, but they aren't directly interchangeable as the o/d box needs the ecu from the 16v injected engine to operate. Same goes for the auto from the late Jimny's. I have heard, but don't quote me, that the Holden trimatic will fit. Maybe someone else can confirm?
NuSkewdy
Post by NuSkewdy »
Has anyone out there done a changeover to a box with O/D on a non-16 Vave motor?
Return to “Suzuki”
