Jerry wrote:so if you have a winch and are pulling out heavy stuck nissan it drains both batteries
In that situation, ya need a flux capacitor.
Sadam_Husain wrote:My understanding of the isolation relay is they close the contacts when they sence 13.x volts which is the alternator output, this means the 2 batteries are isolated from each other when the engines not runing and they are connected together in paralell via the relay when the engines running and the alternators charging.
Cloggy_NZ wrote:Sadam_Husain wrote:My understanding of the isolation relay is they close the contacts when they sence 13.x volts which is the alternator output, this means the 2 batteries are isolated from each other when the engines not runing and they are connected together in paralell via the relay when the engines running and the alternators charging.
Land Rover is stuck to the door handles in water with the engine dead, I will want both batteries to provide everything they have got to get me out of that predicament. I definitely don't want them isolated then.
So I guess that answers the question about the isolation relay. Don't need one of them.
But when back on dry land and the engine started again, there would surely be an advantage to get one battery fully charged before the second one. Logic has it you can charge one battery in half the time you can charge two batteries. One fully charged battery is better for starting the truck than two running in parallel and only half charged?
So do we need some sort of voltage sensing relay which isolates the batteries only during charging?
Red90 wrote:I was thinking alnog the lines of something like this
http://www.traxide.com.au/trax1sc80_2.html
What do you folks think?
Best idea yet, for installation and flexibility.
One MAJOR drawback, it's limited to a max of 80 amps. Most modern alternators can produce 140 amps. so for winching operations, only the third option is practicable.
Note my post earlier, with the 140 amp CS-relay
scs wrote:I can see one problem with this setup. lets say you have computer controlled injection, you turn your truck off and run your isolated battery so stupidly flat, it cant supply any power at all. Now when you come to start the truck, yes the motor turns over, but the isolated battery has no power to trigger the ignition, ecu, fuel pump etc. ne way I can see away around this is maybe having a secondary switched wire between the 2 batteries, bypassing and isolater switch and if you run the acc battery flat, you can flick this over and power up the ecu and fuel pump. alternatively you can run the ecu ignition etc directly off the starting battery through relays.
scs wrote:just saying if you set it up wrong and your engine electronics rely on the aux batt while the starting batt is isolated and youve flattened it, it wont work.
Moriarty wrote:
The whole point of the exercise, is so you DONT run your SERVICE battery flat, only the Aux battery.
That what my setup does anyway.
Smurf wrote:scs wrote:I can see one problem with this setup. lets say you have computer controlled injection, you turn your truck off and run your isolated battery so stupidly flat, it cant supply any power at all. Now when you come to start the truck, yes the motor turns over, but the isolated battery has no power to trigger the ignition, ecu, fuel pump etc. ne way I can see away around this is maybe having a secondary switched wire between the 2 batteries, bypassing and isolater switch and if you run the acc battery flat, you can flick this over and power up the ecu and fuel pump. alternatively you can run the ecu ignition etc directly off the starting battery through relays.
Easy, fit one of these,
http://www.projecta.com.au/catalogue/cid/23/asset_id/53
I have one and all you need to do is pop the bonnet, push a button and jump start yourself, easy as.
Moriarty wrote:I am Curious, George, (sorry. {NOT} about the dreadful pun) wonder what cost? would be practicable for me to change to that better device, allowing a substantial revers current for starting?
Or just install a manual isolating switch in the cab, so if the service batt DID (and bloody well does) go flat, I can start again?
Be cheaper too.....
First time I was lucky, was on the long downhill slippery slope, managed to roll start.
Jumper leads live in the truck as a matter of course, part of my 4wd kit.
But I was wondering about the electric winch guys. a manual switch, less to go wrong, and then double the batt capacity for a harder recovery? Comments?
B.
