WANTED hilux lift kit
jimmyb
Stropper
Post by jimmyb »
Hello
I have a 1986 LN61 hilux surf and I am keen to fit it with a suspension lift kit. It has leaf springs and beam axles front and rear, just wondering if any body can point me in the direction of a cheap way of jacking it up.
Thanks very much.
86-surf
Re: WANTED hilux lift kit
Post by 86-surf »
maxitrac heavy duty lifted springs.. i got mine for my 86 surf (ifs)for $115 each spring but that was just for the rear.. and get some maxitrac lengthend shocks to
From repco.. where are you located?
I think you can fit rear hilux springs in the front to? but im not sure, some one from here will say if this is true or not
Smurf
Post by Smurf »
You have several options, depending on what you plan to use the truck for.
body lift, only really good to help clear bigger tyres or make it look taller.
extended (longer) shackles, can alter your front wheel alignment and driveshaft angles. tends to make your truck roll around on the road a bit more though
Re arc your existing springs, works well, cost effective BUT the springs can sag again
Buy new springs with a 50mm lift, usually gives you a harsher ride on road, though the maxitrac springs Supralux sells sound like they work well.
If you do lift your truck with a suspension lift it would pay to replace your shocks as well.
An LN/YN61 Surf has Independent Front Suspension
An LN/YN60 Surf has leaf springs all round
COMILUX
Post by COMILUX »
ive just lifter my 87 hilkux d-cab
got maxitrac 50mm lift springs from steve (supralux) @ 4wdstuff.co.nz and put in a 50mm body lift.
springs are great they are good on the road and even better off road. only fitted body lift to clear some bigger tyres so as was said above it depends what your plans for the hilux are.
Nick
027 337 0579
jimmyb
Stropper
Post by jimmyb »
Excellent, thanks very much for your info and ill follow up on what you have told me, it is a 1986 surf ssr ltd definitely has leaf springs all round. Full electrics which is a pain because half of it is not working any more – water does that I suppose. :D
Ill keep you posted. Cheers!
Smurf
Post by Smurf »
jimmyb wrote:Excellent, thanks very much for your info and ill follow up on what you have told me, it is a 1986 surf ssr ltd definitely has leaf springs all round. Full electrics which is a pain because half of it is not working any more – water does that I suppose. :D
non working electrics is just a Toyota thing with this model, the rear window is a common failure, there are fixes available if you surf the net. also the switches for the power windows get filled with dust and the contacts bend, reasonably easy to open the switches and fix/clean them though.
Where in the country are you?
jimmyb
Stropper
Post by jimmyb »
Hello
I had a play with the rear window, the guy I brought it off put the number plate bolts in too far and jammed the regulator! And yep I took all of the switches apart and cleaned the contacts so they are all go now, all be it a little dicky.
I am in Christchurch NZ
86-surf
Post by 86-surf »
jimmyb wrote:I am in Christchurch NZ
BLody christchurch!!!!!.
It's toyota heaven down there!
jimmyb
Stropper
Post by jimmyb »
They all seem to come form Kaiapoi and rangiora for some reason, i got mine for $900.00 with wof reg and 10,000km RUC only problem - engine run a bearing. i am on the hunt for a 2L 2LT 3L engine, bring on those rusty/chrashed toyota vans vans
Jafa
Post by Jafa »
I can do you some Bilstein 5125 10",12" or 14" Shock - $155 ea
or Bilstein 5150 for $200 ea
Jafa
021 273 9942
jafa@inspire.net.nz
jimmyb
Stropper
Post by jimmyb »
thanks for the offer but it already has a set of munroe shocks, if any body can help with some of those white spoke rims would be really good. I have managed to track down a 2LT engine to fit to it :P
Poacher-HILUX
Post by Poacher-HILUX »
Gday.
Just got a a full set of costom made 4' raised tough dog leaves.
Is repco the place to get lengthend shockies from?
anyone wanting to sell cheap 50mm body lift to??
Return to “Toyota”
