k&n pod air filter on 1kzte
uwish
Post by uwish »
for road use is it safe to put a k&n pod air filter on a 1kzte in a kzn185 surf sumwhere in cold air?
COMILUX
Re: k&n pod air filter on 1kzte
Post by COMILUX »
Its not going to hurt it as long as your not using it off road through rivers ect, problem is you would have to build a cold air box to keep it cool so id recomend going for a k&n panal filter to fit in the factory air box. you can always put a snorkle onto it to get cold air to it and you would have no wories if you get the temptation to cross the odd river.
027 337 0579
Return to “Toyota”
