iv got a solid axle surf and it has a cronic pull to the right under braking. ive adjusted the rear brakes bled them.
can anyone help with this problem?
85 solid axle hilux
Re: 85 solid axle hilux
probably a dumb answer, but i take it you have equalised the front tyre pressures?
mine was ultra sensitive to uneven pressures, especially on the 33's. would only take 5 or 6 psi differenceto make it pull quite badly under brakes.
Check the torsion bar on top of the front diff. If it has come away or is loose, then you get wicked brake steer.
- mud_slinger
- hosehustler
rokhound wrote:Check the torsion bar on top of the front diff. If it has come away or is loose, then you get wicked brake steer.
I'll agree with that, before I went to crossover steer that bar on the to of my diff broke free twice, once it snapped the housing point on top of the diff, the 2nd time it ripped clean out of the chassis....and yes without that bar in place (between top of diff and back to chassis) it will pull wickedly under braking.
I hate signatures
ok cheers guys ill have a check and let you no. i did a bit of checking the left front works jus not as well as the right.
is there a way you can adjust the front brakes other than bleed them?
