Ok guys i need some help
I'm trying to hook my rear window up to the up/down switch in the center consol,
Ive got the window going down by using the switch but can't figur out how to get the window to go up by using the switch,
I got the window going down with the red/black wire to the + and the blue/red wire to the - And the + to the window going to the red/black wire, And the - To the Green/yellow wire,
Any help would be good, I want to get it done befor 3:00 because i start work at 3,
Thanks
Thanks
Re: Ok guys i need some help
Oh and there are two more wires a Red/yellow one and a Green/blue one?
Can any one plz help me out here?
- hosehustler
Are you wiring permanently to 12 V (bypassing the circut board) or trying to get it going from the std switch ect through the circut board??
I hate signatures
Strait from the battery to the switch then strait to the window motor
- hosehustler
will have a good look today at the colors of wires....but you need a switch which has 6 pins (for wires), and must be a return to centre on its own type switch, otherwise it gets left on and pops the circut breaker all the time (which is by the fuse box)
I hate signatures
Thanks,
looks like ill just be touching the wires to geather again
- hosehustler
You need to locate the (large wires behind left rear passengers kick panel) plain blue wire, blue with black stripe, blue with yellow stripe and white with black stripe........those are the 4 important wires.
I'm in the midst of a body swap at the mo so can't tell you where to put each but you'll find two of those wires head back to the motor,one is power supply, and one is earth, all you nee to do is get your 6 pin plug put 12v (linked) to both centre pins, and then revers the polarity between front pins and rear pins on switch (using wires mentioned) and it will work.
Hard for me to explain on the keyboard, i will be re-wiring my new body in a week or so and can be more specific then.
anyway hope that helps, locate the mentioned colours....buy 6 pin rocker switch and wire away
good luck.
Tim
good luck.
Tim
I hate signatures
thanks..
Where the hell would i get a 6 pin rocker switch??
gazza wrote:breakers out of a surf
Hahaha umm breakers?, Info plz? lol
- hosehustler
86-surf wrote:thanks..
Any auto electical shop should sell one, they aren't that cheap....expect to pay $30-40
make sure you get a spring loaded return to centre one tho
I hate signatures
hosehustler wrote:....expect to pay $30-40
OMFG I'm fine i would rather touch 2 wires to geather then payy $30 for a switch!, Unles my mum payed for it
- Sadam_Husain
- Angry bird
86-surf wrote:OMFG I'm fine i would rather touch 2 wires to geather then payy $30 for a switch!, Unles my mum payed for it![]()
If you've got a DSE, Jarcar electronics or super cheap autos in rotovegas you should be able to find one to suit your budget Jase
- hosehustler
86-surf wrote:hosehustler wrote:....expect to pay $30-40
You may get on to something cheaper but......do it once do it right
first you will know of it, the local fire brigade will be in your driveway dampening down the wreck that was once your ride
trust me hard wired 12v switches are worth paying $30 bucks for
I hate signatures
hosehustler wrote:86-surf wrote:hosehustler wrote:....expect to pay $30-40
You may get on to something cheaper but......do it once do it right, touching wires together is fine for a while, at some point those wires will touch something on their own...unmolestered....and you won't be there
first you will know of it, the local fire brigade will be in your driveway dampening down the wreck that was once your ride![]()
Well it might be worth the money will seeee,
I just Have a wire thats conected to the rear window motor that i pop the bonnet and touch on the top of the battery
SRY Jase breakers is what we call then in england think you call em wreckers here should get original switch for bout $5 or less. Think theres a couple of surfs up pickapart good luck
NO one remembers who comes 2nd....!
Jase
try King Commerical ( WRECKERS) at Ngongotaha if not, I have a spare as I dont have a canopy anymore (so when are you picking that up as well..) If you have the old switch out, bring that with you as I can sometimes seperate them and clean the contacts. Most times these switches stop working is because the contacts get clogged up with dirt etc
i sent you a few pms asking you wen do you want me to pick it up but no reply,,
i know the contacts are alright because i switched the wires arround and it worked so not the contacts,
- hosehustler
Have a read through of this link Jase, "4runners" in the states are "surfs" in NZ
yours will be a 1st generation 4runner
http://www.4crawler.com/4x4/CheapTricks ... ndow.shtml
I hate signatures
