I (well I watched) changed my front open diff to a LSD the other day (week), now it has sprung a leak on the drivers side. Anyone got any quick fire idea's about what the issue would be?
Reece, has my warrenty run out yet?
Leaking diff oil
Leaking diff oil
Benjamin Franklin
Benjamin Franklin
- Sadam_Husain
- Angry bird
Re: Leaking diff oil
Where is it leaking from?
Pinion, swivel seals, hubs?
The short answer is you've got a leak anyway?
i thought it was just marking its territory?
turoa wrote:i thought it was just marking its territory?
Very funny Tu's, problem is, it's marking to much territory
Sadam, I think it's the swivel seals although don't qoute me on it
Benjamin Franklin
Benjamin Franklin
- Sadam_Husain
- Angry bird
Theres oil seals in the end of the axle tubes where the swivel housings are, you've probably damaged one when the axle was put back in. The seal stops the diff oil flowing into the swivel housing.
Mine leak
Mine leak
$3 seal .... pain in the ass to get out and replace....will be a pinion seal or something ...is it leaking on the big ball thingy? and how bad is it? easier with a full floater axle like yours though.....
- Sadam_Husain
- Angry bird
Jerry wrote:$3 seal .... pain in the ass to get out and replace....will be a pinion seal or something ...is it leaking on the big ball thingy? and how bad is it? easier with a full floater axle like yours though.....
Jerry you'll have to put your reading spec's on, its the front diff and its leaking from the swivell housing not the pinion.... I thought we taught you what all these part thingies are
Bubba wrote:Reece, has my warrenty run out yet?
Tail light warrenty Bubba, when I can't see your tail lights the warrenty it's void.
Drivers side you say? Didn't pull the whole axle out of that side.... it was Abbo's fault anyways... he kept handing me beer when I needed a wrench.... bloody Abbo!
suzuki1k wrote:Bubba wrote:Reece, has my warrenty run out yet?
You didnt say no everytime i handed you one
Don't have 4wd.
my side not leakin is it i would suggest you get a seal and we can fix that on sat as well..........
WARNING:
