i talked to a mechanic about it , I had the drums of a few weeks ago cleaning and adjusting rear brakes, Now after a trip up north its leaking really bad, It also has play it , in and out descriced by the machanic as end-float or N float.
So this week im short on money as also replacing starter motor so i would like to try replace myself.
Ive ordered a new wheel bearing kit.
any advice on replacing it.. ill need to use a small punch and a hammer to gently hammer in the bearing is that right?
or do bearings need to be pressed in/out ?
do they need adjusting or do they sit in place?
will i need to grease the bearing or is it likely pre greased?
and do you think this is something I can get stuck into and work it out and replace myself , Or is it a bit tricky and should leave it to an expert if i dont have much knowlege?
thanks for help.
