fj 40 diff chang out
- kruza wazza
hi all, i a m runnin 4.1 ratio up fronnt and 3.7 on rear, dont ask me wh y , i bought it like this, need to no can i pull axles and remove 3.7 head from diff and put in 4.1 head and reinsert axles and go and hpoof it or is this a bit more complicated , your s in toyo warwick, check out my new page with pics if u want
- MNC
Re: fj 40 diff chang out
Have you got a full floating or semi-floating rear end?
Either way its not hard to do. If full floating - yeah you got the idea (undo bolts on hubs and pull out axles), if semi-floating just take the plate off the back of diff pull out clips holding in axles from there.
Then just remove drive shaft and diff head - and replace in opposite order. Simple
- kruza wazza
hi, am naive about what is full floatin and not , please explain more , cheers
- skid
- Tyre Man
where abouts are ya dude
then we can send one of the ORE cruiser gurus round for a beer or two and they can pass on thier knowledge
- Sadam_Husain
- Angry bird
kruza wazza wrote:hi, am naive about what is full floatin and not , please explain more , cheers
MNC wrote:Either way its not hard to do. If full floating - yeah you got the idea (undo bolts on hubs and pull out axles), if semi-floating just take the plate off the back of diff pull out clips holding in axles from there.
This is a full floating axle with the hub sticking out, a semi-floating axle dosent have a hub and the end of the axle is flush with the inside of the rim, dissasembly is as MNC said
- MNC
The best thing you could do is buy a workshop manual off trademe. Should get one for under $20 and it'll explain with pictures what you should be doing. That's how I've learned - and if there aren't enough pictures there are always heaps of cruiser guys on here to help out
call into huntly for a beer and ill show you step by step...bring your truck and we can do it in under an hour including trying to get you out of my old dog in the garage
- skid
- Tyre Man
damn, reading your other post it seems you are in the wairarapa
damn shame, coz a few of the welly boys were over there helping william hamilton the other weekend
get hold of william, he should know how tochange diffs by now
theres plenty of others over there who may be able to help
otherwise you have to get all the bits, all the beer, all the food, and put out a mass invitation and folks will come, cheers
- kruza wazza
all good , thanx for that, i have a semi floater not a full floater, what is the difference which is better for off road? warwick
- kruza wazza
wiliam hamilton has contacted me , he said to come around and he would put a pig on a spit!
- williamhamilton
kruza wazza wrote:wiliam hamilton has contacted me , he said to come around and he would put a pig on a spit!
Don't forget your whittling knife and we can brew up sme good ole moonshine YEEAAHH HHAAARR (That was supposed to be in a Cousin Jerry like voice)
W
- kruza wazza
been and seen ol will, seems a good enough bloke, hes lucky he has 2 fjs, had a pig on the spit and 12 bottles moonshine, al goood
and no beer left thanks to taz and reece, nice to meet you in person
