WAS fume'ing (now more of a flaming thread...)
Kiwimidi
Re: WAS fume'ing (now more of a flaming thread...)
Post by Kiwimidi »
Bulletproof wrote:
Kiwimidi wrote:since you lot are so knowledgeable :lol: . what happened to this piston? was it a result or running lpg? I realise the marks on the top of the piston are from the bits of ring bashing into the head but what about the big hole down the side
quote]
Did you buy that truck from Clyde ?
Were you feeding LPG into it ?
Cheers Richard
the truck has had lpg thru it but not at the time this happened. truck not bought from clyde.
mudzilla
Post by mudzilla »
Kiwimidi wrote:
mudzilla wrote:Maybe thats from you lowering the boost and leaving the fuel wound up then towing a dead Nissan a couple hundred Km with your foot on the floor ,,, At a Guess ... :?
The nissan was definatly part of the problem. I did turn down the smoke quater of a turn. do you think it was over fueling??
Possably,, When you got the truck it was running extra fuel and extra boost and went well .. Maybe buy lowering the boost and not backing off enough fuel or backing off the fuel and continuing to run high boost may have been enough to get the exhaust temp to high and melt the piston.. Running hard (towing a heavy Vehical ) for a long haul and not having an Exhaust temp gauge to keep an eye on may have been the fatal blow for the poor old thing .. :(
Bulletproof
Post by Bulletproof »
A melt down like that would not be the result of previous LPG use.
A melt down like that would be the result of the pyro temperature too hot on the day . It is something that happens instantly when the temperature gets over a certain point.
I have done it with motor bikes in the past.
Probably caused with over fueling and foot to the floor.
Cheers Richard
Never say die, up man and try
Kiwimidi
Post by Kiwimidi »
so your both saying i should wind more boost into it to avoide this happening again. sounds like fun :D
Bulletproof
Kiwimidi wrote:so your both saying i should wind more boost into it to avoide this happening again. sounds like fun :D
Actually what you are saying is right. I have a manually turned on supercharger and when I switch it on my pyrometer drops 100 C with the extra air going through the motor.
The other choice is to turn the fuel down.
Cheers richard
burned a hole in a piston on my 351 cleveland as the dissy was jammed at full advance
Moriarty
Post by Moriarty »
Guessing here and the guess is based on dead engines running petrol and two stroke racing bikes.
That piston bears all the earmarks of a ring failure. the short bits bounced up and down eroding away at the lands until finally breaking through. As the ring turned around, bits broke off went up on top, making interesting engraving marks and buggering off down the divorce pipe. probably even gave the turbo a smack or two on the way.
The melted bits are created AFTER the ring failure.
Question. Why did the ring fail?
Answer. because it failed. fuknose.
I can tell WHY the sky is blue though.
Kiwimidi
Post by Kiwimidi »
Moriarty wrote:Guessing here and the guess is based on dead engines running petrol and two stroke racing bikes.
This is what i assumed happened i just thought i would ask the question if the gas had contributed to the prematuer faliuer fo the ring.
mudzilla
Post by mudzilla »
Is that another GUESS Bob :?
Bulletproof
Rings generally fail and break because with the piston getting hot and expanding they jam in the groove.
Excessive carbon build up in the groove can also bring this on.
Other things causing failure is lack of oil in the bore or a faulty cooling system.
All of these things cause heat and a ring generally won't break unless it jams in the groove.
Cheers Richard
Moriarty
Post by Moriarty »
Nope, this is proven as to blue sky, not a theory.
(Havent heard back from Ghana yet.)
Moriarty
Post by Moriarty »
Bulletproof wrote:Rings generally fail and break because with the piston getting hot and expanding they jam in the groove.
Cheers Richard
Generally speaking, you are right, all of those can be, and GENERALLY are, contributing factors. But are not the ONLY reasons.
wopass
Post by wopass »
ohhhh i have something else to add here but cant yet...
8)
flyingbrick
Post by flyingbrick »
:lol:
i love this thread.
DieselBoy
Post by DieselBoy »
wopass wrote:ohhhh i have something else to add here but cant yet...
8)
Dooooooooooeeeeeeeeeeeeeeeeeeeeeeeeeet!!!!!!!!!!!
:mrgreen: :mrgreen: :mrgreen: :mrgreen:
wopass
Post by wopass »
DieselBoy
Post by DieselBoy »
Hmmmmmmmm, wow, look at the torque figures!!!!!
Is that over 1000nm i can see??
wopass
Post by wopass »
DieselBoy wrote:Hmmmmmmmm, wow, look at the torque figures!!!!!
1390nm fume off
1475nm fume on
wopass
Post by wopass »
ohh and its fuel economy including adding the lpg to total is averaging 8.5km-ltr and thats rolling 35" tyres all the time :mrgreen:
vvega
Post by vvega »
nice :D
should have thrown the missle on there :d
are you still planning the christmas refresh ??
do you want me to price up some bits for you for it ??
we just got on capricorn so a rods etc just halfed in price ... :D
Kiwi4x4
Moriarty
Post by Moriarty »
wopass wrote:ohh and its fuel economy including adding the lpg to total is averaging 8.5km-ltr and thats rolling 35" tyres all the time :mrgreen:
For us of more mature years, that translates back to 24 MPG which is VERY respectable, considering the way its driven, as if it was a little old lady doing her shopping. Wonder how it would go driven a litttle more aggressively?
One who spilt milk in it and didn't tell the owner? Cruel, that.
smurf182
Post by smurf182 »
1390nm fume off
1475nm fume on
A 6% increase?!?!
:shock:
curly12
Re: fume'ing
Post by curly12 »
KiwiBacon wrote:
smurf182 wrote:
wopass wrote:look at the humble bumble, he shouldnt be able to fly...but he does it with ease :wink:
Urban myth
http://www.sciencenews.org/view/generic/id/5400/title/Flight_of_the_Bumblebee
Just like the 1000Nm cruiser engine. :lol:
Go the cheerleaders Image Image Image Image Image
Jafa
Re: fume'ing
Post by Jafa »
KiwiBacon wrote:
Urban myth
Bumblebees cant fly, its a well controlled jump! :lol: :lol:
021 273 9942
jafa@inspire.net.nz
vvega
Post by vvega »
probably find if you dynoed it a bumble would have over 1000Nm as well :D
i do think it would die if you fumed it though
Kiwi4x4
wopass
Post by wopass »
1390nm fume off
1475nm fume on
A 6% increase?!?!
:shock:
fume made a bigger difference to KW.
Andrew1706
Post by Andrew1706 »
Is that NM at the wheels or at the flywheel?
Hard to see what the graph says.
wopass
Post by wopass »
all 4 wheels with 35" tyres on them :wink:
vvega
Post by vvega »
Andrew1706 wrote:Is that NM at the wheels or at the flywheel?
the ONLY way you can measure flywheel Nm is ... on a engine dyno
if they try to gove you that off a rolling road or chassis dyno .. its a made up figure
Kiwi4x4
mudzilla
Post by mudzilla »
vvega wrote:if they try to gove you that off a rolling road or chassis dyno .. its a made up figure
As long as before and after numbers (right or Wrong) are done on the same dyno you still see your % gain.
Good on ya Wop.. I want to see how it Hauls the Missile on your trailer now 8)
