Hi guys, after the intake manifold, tps and rocker cover as im intercooling my 1kz, or even the tps part???
Phil
1kz intercooler bits etc wtd
Re: 1kz intercooler bits etc wtd
tps is the same between intercooled & non intercooled just has different throttle body. which i have in the garage but not sure what they are worth? as for the rocket cover it can be modified to suit the intercooler.
89 LN106 Hilux 3.0L turbo,2" bodylift 50mm suspension lift, lockrite rear, lsd front & 33" wranglers & winch
the tps throttle body the same is it? just different location where it sits on the intake manifold? is there any chance of having a look?
philux wrote:the tps throttle body the same is it? just different location where it sits on the intake manifold? is there any chance of having a look?
throttle body is different but same tps(throtle position sensor).
