im after a 5m crank and 1 conrod, i have a motor that ran a bearing rather badly.
so need new crank, dose anyone know if a 6 or 7m crank will fit?
Craig
5m or 7m parts WTD
Re: 5m or 7m parts WTD
surf10 wrote:im after a 5m crank and 1 conrod, i have a motor that ran a bearing rather badly.
Craig
have 7m short block in bits for sale
- rangimotors
from what i have read, (haven't stuffed one yet thankfully) 5m 6m and 7m cranks are all different.
rangimotors wrote:from what i have read, (haven't stuffed one yet thankfully) 5m 6m and 7m cranks are all different.
Yeah I read the same when I was after that 5mge ute in Timaru. Think the heads between the 5 and the 6 are the same but the 6's shaft is stroked or something.
ok so im looking for a 5m crank,
surf10 wrote:ok so im looking for a 5m crank,
no, as u said the other day ballbag you havent done an engine swap yet...2jzgte!
Ryan
LN130 Surf: Coiled SAS, 35" BFG M/T's, Lifted, Rear Lockright, Snorkel, CB, On-board air
Soon to be 3.8 commy powered, front ARB Air Locker, custom bar work, winch...
you donate the motor and ill put it in
