Wtd TOYOTA Manual locking hubs
After a pair of manual locking hubs to fit 8" toyota prado front diff, solid axle, not sure if it will take same hubs as hilux???
- hosehustler
Re: Wtd TOYOTA Manual locking hubs
I take it you're ditching the electric prado hubs
I'm running a prado axle on my surf, the manual hubs won't work without adapters unless you swap the stub axle, I used 70 series cruiser stubs, (or you could use hilux) they will bolt straight on to the prado swivel housing, you can use your original hubs and bearings (they are the same) then you can use a std hilux manual 30spline FWH, get a pair of aisin ones they are the strongest.
I hate signatures
I've got 2 adaptor plates spare sitting in the garage that suit prado to manual hubs ....., option b is convert them....., 3rd option is PM oldblue and get him to convert your electric hubs to manual ones.
Thanks Jerry, I was just going to say that,and I also have a set already converted to manual if you don't have your old hubs, these are complete with studs ,nuts,collets ,and bolts, etc
how much would you take for the adapters? yea the hubs are incomplete i never got any electric lockers just parts manual ones...
