surf rear driveshaft wanted
bigstu
Post by bigstu »
Im after a rear driveshaft for surf as im moving my front axle forward 90mm ish with rears up front and locater holes in spring seats moved so was planning to get a rear shaft butchered to suit hopefully this will work not sure what others do? doesnt need to have mint ujs as i only really need the tube section to be cut to size and mated to my front joints.
Thanks Stu
