2L (2.4) hilux
mattscruiser
2L (2.4) hilux
Post by mattscruiser »
Can i turn up the injector pump if so where do i turn it up
cheers john
tweake
Re: 2L (2.4) hilux
Post by tweake »
have you fitted a turbo to it ?
mattscruiser
Re: 2L (2.4) hilux
yes one off the 2lte and now it doesnt blow black at all
tweake
Re: 2L (2.4) hilux
Post by tweake »
if power is up i would be inclined to leave it. you could have been overfueling enough to start with.
if you want more then fit EGT guage and adjust screw on the back of the pump. just be aware without a boost comp if you wind it up you will have a point where you will be way overfueling. minor adjustment might be ok but for anything decent get a boost comp off a 2lt injection pump.
mattscruiser
Re: 2L (2.4) hilux
hi is it the adjustor above the injector lines which direction do i turn it and how many turns would you recomend to turn it . the truck is purely for offroad so any recomendation will be appreciated
Lynx
Re: 2L (2.4) hilux
Post by Lynx »
is it a 2lt or 2lte injector pump?
Cheers Daniel
mattscruiser
Re: 2L (2.4) hilux
hi its a 2l with the original injector pump
tweake
Re: 2L (2.4) hilux
Post by tweake »
i can't remember what they used to do (1/8 turn, 1/4 turn ??) but if yours was overfueling to start with then that throws it out the window.
fit an EGT guage !
poor mans way, turn it up a fraction take it for a quick drive. if it blows a cloud of smoke (ie more than a puff) when you stand on the throttle then back it down a bit and retest.
you don't want it blowing to much smoke otherwise you will just blow the weak head.
mattscruiser
Re: 2L (2.4) hilux
ok thanks we will tow it out and try are luck
mattscruiser
Re: 2L (2.4) hilux
thanks for your help the wire with the seals were still on the injector pump whether it was still original i dont know but it goes alot better now
Return to “Toyota”
