97 VZN185 Hilux Surf
james46
Newbie
Newbie
Post by james46 »
Hi anybody know if there is a winch bullbar out there to fit my VZN185 surf? & if 31s are the biggest I can go without a lift? cheers.
rokhound
Re: 97 VZN185 Hilux Surf
Post by rokhound »
If it has factory SRS bags you will need an airbag compatible unit. ARB , TJM and Eastcoast come to mind. Also try smartbar.
NJV6
Post by NJV6 »
ARB do.
PM Badnuz for options on ARB
gimmemud
Post by gimmemud »
ARB don't and neither do ECB. ARB do one for a 95 series prado which is very similar and can be made to fit a 185 surf but doesn't fit 100% and the airbag sensors are a bit different. The TJM T15 bar is pretty much the only one you can get here or aussie unless go get one via the states.
NJV6
Post by NJV6 »
I should correct what I said, yes you can get ARB air bag compatiable ones that fit a 185 surf. But you can't modify the mounts to suit a body lift, but there are means and ways around it.
A friend has one with a body lift and beam axle conversion with ARB bar and air bag's.
james46
Newbie
Newbie
Post by james46 »
rokhound wrote:If it has factory SRS bags you will need an airbag compatible unit. ARB , TJM and Eastcoast come to mind. Also try smartbar.
Yea roger that, thats my reason for looking out for the correct bar, rather than altering one off something else. thanks
koma
Post by koma »
what else are you doign to it, or have done? I've got a kzn185 daily driver but wouldn't mind gettign abit further with it. What was the beam axle coversion like to do? cheers
Lynx
Post by Lynx »
koma wrote:what else are you doign to it, or have done? I've got a kzn185 daily driver but wouldn't mind gettign abit further with it. What was the beam axle coversion like to do? cheers
Depends on how much of it you can do yourself, have a search these a few good threads on it.
Cheers Daniel
NJV6
Post by NJV6 »
Beam axle is a much bigger job on a 185 than an earlier surf due to passenger side transfer drop and rack and pinion steering.
Return to “Toyota”
