Hi I'm after some nissan free wheel hubs for a gq y60 safari.
am after the nissan ones not after market. hope someone has a set laying around.
Thanks Mike
WANTED : gq free wheel hubs
Re: WANTED : gq free wheel hubs
Goodluck. I never found any and if you do manage, you will probably pay quite a bit of coin for them. I'm going to keep a look out in Oz for a set when I'm over there next month. Going to head down to my mates local wrecking yard.
Al
Al
I couldn't find any either so got force nissan ones. I don't drive like an animal but they work perfectly. I've heard they can take a hiding. Don't know anyone else with em though.
we've got some of the auto hubs with the manual override here, but I think the deal was the auto part was faulty (or something? not too sure) I can dig them out and find out what they're like if they could be of use to you?
thanks jeremy that would be good
4WDBits are doing copies of the genuine Nissan ones
Rural53 wrote:4WDBits are doing copies of the genuine Nissan ones
They are the ones I have and they've worked mint for me.
The auto ones like the ones in the link are what shat themselves on my truck.
Force Nissan Y60 manual free wheeling hubs are manufactrured as indentical replacements of the well respected late model Y60 Nissan OEM manual free wheeling hubs.
These hubs feature extra tough machined billet alloy main housing, heavy duty steel locating sleeve to keep hubs centric under extreme loads and steel dowel location of internal gears.
http://www.4wdbits.co.nz/ProductDetails ... uctID=1485
Well priced for top quality gear
And they're significantly cheaper then branded aftermarket ones!
Al
Al
hi if thay are the auto ones then i have a set ???
thanks, mudy1 but need the one's that can be locked manually.
Albundy not sure you will find them cheaper accross the ditch unless they are mates rates, my brother is on the gold coast and he is saying they are much more expensive than here.
