1kzte problems
RustySurf
1kzte problems
Post by RustySurf »
Looking at buying a 1kzte surf thats had the engine rebuilt with a brand new head fitted, it smokes quite badly and knocks a bit when starting off(its auto) but once it hits boost it runs fine and has plenty of grunt.
tweake
Re: 1kzte problems
Post by tweake »
probably got the throttle sensor not adjusted correctly or the egr stuck open.
RustySurf
Re: 1kzte problems
Post by RustySurf »
great are both easy fixes?
tweake
Re: 1kzte problems
Post by tweake »
come to think of it possible injection timing as well. easy enough to fix.
btw i assume its black smoke.
kbushnz
Re: 1kzte problems
Post by kbushnz »
Hi yah
Down load the 1KZTE engine manual.
Use the troubleshooting section.
Also has all the setup info for timing etc etc.
Will help / answer alot of your questions.
http://daemon4x4.org/portal/downloads.php?dcid=17&p=1
Lots of other good toyota stuff on this site, also a bit of Nissan and LR.
Calvin
tallsam66
Re: 1kzte problems
Post by tallsam66 »
Find out what sort of head they put on it... ie Toyota or after market.... & if the head bolts/studs were also replaced.
They should of also put on a new waterpump , thermostat & had the radiator rodded.
Heath
Re: 1kzte problems
Post by Heath »
If you are in Auckland get Alltech on the shore to have alook also. They'll pressure test it too. Not bad on their prices as well.
Return to “Toyota”
