wanted urgently rear window to fit a 1991 hilux would prefer sliding type.
rear sliding window for a hliux
- possum70
- It was a Ford Hilux I think?
i'n not having much luck with windows at the moment
Rattley old Hilux !!!!
V8 Cruisers Rule!!!!
Re: rear sliding window for a hliux
whole unit including frame or just glass only?
- possum70
would prefer just one pain of glass, (passengers side) but will buy the whole unit if i have too
possum70 wrote:i'n not having much luck with windows at the moment![]()
What did you do mum....?
Don't have 4wd.
So you need the fixed pane on the passengers side?
Will see what I can find.
Although as these are flat, any windscreen out fit should be able to help you out (even if they have to cut one).
- possum70
abbo wrote:possum70 wrote:i'n not having much luck with windows at the moment![]()
over loaded my truck and something went through the back window
- possum70
rokhound wrote:So you need the fixed pane on the passengers side?
i'll put up a pic tomorrow so that you can see what i mean, i'm not the best at explaining things
tried smith and smith they would do it
If you just need a simple square bit of glass, you should be able to go to a glass manufacturer and they'll be able to cut you up a bit. Somewhere like national glass would do it, they throw away heaps of different glass if it's been cut wrong etc.
- Beer_Cruiser
Try these guys Autoglas Stieger Ltd
32 Hania st ( behind Honda on Kent Tce)
0800784343
They seemed fairly onto it
0800784343
Or have a chat to Graham .... he might have some contacts
- possum70
i've got one
nz car parts it was the cheapest round goes in today
