4.5 hilux 4 pin diff wtd
J_Dub
Post by J_Dub »
as above, preferably in auckland-hamilton.
for 85 hilux
turbo6
Re: 4.5 hilux 4 pin diff wtd
Post by turbo6 »
ive got a 4.556 ratio , 4 pin lsd from a 1991 hilux surf
J_Dub
Post by J_Dub »
needs to be open to fit a locker
turbo6
Post by turbo6 »
are you still after a open diff? as my new truck has one which i wanna put my lsd into.
Bulletproof
Post by Bulletproof »
Hi Jdub
You are asking for the wrong thing. What you need is a diff nugget out of an early prado or 130 Surf with the stronger housing and then fit your locker into that.
Cheers Richard
Never say die, up man and try
nzhunter
Post by nzhunter »
turbo6 wrote:ive got a 4.556 ratio , 4 pin lsd from a 1991 hilux surf
How much do you want for it?
Jdub. I got an open 4.55 4 pin open lux diff if you want it. Not sure on condition though, i think it may have a leaking pinion seal
Bulletproof
Here are all the hilux diffs
The one on the right is what I run and is the strongest.
The V6 is also strong. It is no use having strong gears if the housing flexes
The one on the left is a std hilx
Cheers Richard
J_Dub
Post by J_Dub »
how much mate?
nzhunter
Post by nzhunter »
how much mate?
i duno $150? i gota check it first out though but yeah
