my left hand upper steering arm knuckle has cracked and broken if that makes sense..
the steering linkage rod that goes from the steering box to the left front hub, the piece that that bolts to and it's held to thr top of the swivel housing on the four studs...
I need one of them asap in chch if anyone has one? wanted to use truck this w.e but wreckers not open tomorrow!
anyone?
thanks
KZJ78/LJ71/78 Steering Arm Knuckle NEEDED!!!!!!
- IcedJohnno
- Trailer Trash
Re: KZJ78/LJ71/78 Steering Arm Knuckle NEEDED!!!!!!
If Laycocks are open tomo, there is my old front axle parts sitting in there. I think there may be a steering arm in there, though that side did not get hit.
These parts belong to either Laycocks or the insurer. You will beed to sort out with Laycocks.
They've just put my axle into a different housing, and replaced the steering box too.
$31hundy damage to axle and steering components alone. Thank God for insurance!
Panel beating was done in Rangoon and involved door, guard, flare and bumper. All on top of the above bill.
What you get when a car drives under your front wheel from behind!
