lift??
crispo
lift??
Post by crispo »
hi there, looking at a set of 33s on tm, i read on hear that they will not fit correctly? is this the case? also i am new to all this, when you guys refer to body lift is this the little round blocks that on tm for about $ 150 i assume they go in between the chassis and body mounts, is this something that a warrant guy would pick up on, therefore needing a cert, i am used to going lower on hiluxs i have had a couple of minitrucks etc ha not went up before ha ha . thanks also if i do get some 33s will they go straight on my 8inch hilux steel rims?? thanks
Filthy4x4
Re: lift??
Post by Filthy4x4 »
Hey dude, yes your correct the body lift are those 10-12 round blocks. My understanding is that you can get away with a suspension lift alot easier than a body lift.
You need a cert for having a 2" body lift (i have been told that you can shave it down so its just under 2" and your sweet but would pay to double check that).
You will need a lift to fit 33s on. As for the fitment onto your rims they should fit fine but anyone feel free to correct me on this.
027 MUD GEAR - (027 683 4327)
Check our facebook:
antsarooney
Re: lift??
Post by antsarooney »
Think you will find any size body lift will require cert.
Big
Re: lift??
Post by Big »
antsarooney wrote:Think you will find any size body lift will require cert.
I was understanding it to be anything under 4"lift didn't need cert BUTyour insurance provider might think otherwise..
crispo
Re: lift??
Post by crispo »
aw awesome il get in contact with the insurance company and see what they say,but i think i would prefer some 32s as seem to be a little cheaper , with less hassle is that correct? i think they fit fine is that rite? my missis controls all the money ha ha hard enough to squeeze the money out of her to buy new tyres ha ha dont let she gana let me do a body lift too ha thanks people. :) :D
Filthy4x4
Re: lift??
Post by Filthy4x4 »
Ive got 32s on my surf at the moment. its standard height in the rear and the torsions have been wound up a little in the front.
Its fine for clearance, no rubbing etc.
Check our facebook:
DaveM
Re: lift??
Post by DaveM »
All body lifts require a cert, but the wof issuer may or may not pick up on it
crispo
Re: lift??
Post by crispo »
aw wicked thats great addvice, thanks all. ill keep looking for some 32s, just the 33s seem to be around 4 sale a bit mre. thanks
Return to “Toyota”
