WTD, Toyota Hi Pinion 4.8 Diff
Mine was out of a Prado. Crown wheel and pinion now stuffed. I'm able to reuse my limited slip carrier. What have you got?
- ClassicCruiserSpares
- Sausage Shack
Re: WTD, Toyota Hi Pinion 4.8 Diff
Oh dare
How'd you manage that? I may know of one ill find out for you.
ClassicCruiserSpares wrote:Oh dareHow'd you manage that? I may know of one ill find out for you.
Ummmm... loud pedal on floor while riding brake...
Cheers, let me know either way
kbjj wrote:Mine was out of a Prado. Crown wheel and pinion now stuffed. I'm able to reuse my limited slip carrier. What have you got?
Bump
Apparently these are out of a LJ78 or LJ71 front
Trust me to use a hard to get toyota bit in my nissan
- Sausage Shack
Did you try callum from dunedin? didnt he have a post with a high pinion diff?
ClassicCruiserSpares wrote:Did you try callum from dunedin? didnt he have a post with a high pinion diff?
Yep, that be a good buy for someone, 4.1 thou
- Sausage Shack
kbjj wrote:ClassicCruiserSpares wrote:Did you try callum from dunedin? didnt he have a post with a high pinion diff?
Arhh ok, they obviously found out the ratio, Bugger. Will keep looking. Have you tried Marshed 4x4 dismantlers?
[quote="ClassicCruiserSpares]Arhh ok, they obviously found out the ratio, Bugger. Will keep looking. Have you tried Marshed 4x4 dismantlers?[/quote]
Never heard of them. I try them tomorrow
- Sausage Shack
The guys number is 0274557746 Hes had a few prados but weather hes got the diff you need im not sure.
you can get them from trail gear and with the current exchange rate maybe worth buying a few as they are getting hard to find now
- muddyhilux
id say trail gear as well,i was just checking stuff out last night and its crazy cheap.i just dont know how to go about freight etc
kbjj wrote:kbjj wrote:Mine was out of a Prado. Crown wheel and pinion now stuffed. I'm able to reuse my limited slip carrier. What have you got?
Bump
Apparently these are out of a KZJ78 or KZJ71 front
Trust me to use a hard to get toyota bit in my nissan![]()
Hey mate just so you know the 4.3 ratio diffs are the ones in the kzj's, you want the front one from an lj. I was in Ace 4wd on the weekend and they had a few lying around on the floor. Give them a call 366 0677
- Sausage Shack
axel wrote:kbjj wrote:kbjj wrote:Mine was out of a Prado. Crown wheel and pinion now stuffed. I'm able to reuse my limited slip carrier. What have you got?
Bump
They dont have 4.8 high pinion ones there, I went and checked.
Bump
Cheers, yeah your right, I'll edit that
I have one now, had to buy a complete front axel to get it. Will look into a trail gear ring and pinion set as a spare for the future.
Cheers all
