Need one ASAP if anyone has one laying around.
Also pretty sure they are the same (V6-V8) except for the pulley, can someone confirm??
Tim
Holden V6 or V8 alternator wtd
- hosehustler
I hate signatures
- tomsoffroad
- Flopsie
Re: Holden V6 or V8 alternator wtd
V6 out of a VN Coma-dore =
Bosch
9 120 060 009
K1 14v 14/85A
92092637
56mm pulley
The hinge bolt is directly across from the adjuster bolt.
Hope this helps
Bosch
9 120 060 009
K1 14v 14/85A
92092637
56mm pulley
Hope this helps
They do try to sell them at different prices Tim, not suere if that makes then different though.
Get a GM one or an original one not a cheap copy Tim.
All I can say is. I went through heaps of the cheap copied ones before going back to the original GM one. No end of problems mate. I lost $1600 bucks worth of Optima batteries in the process not to mention
LOTS of hassles along the way.
Good luck.
See you at Sheffield Mud Plug.
Good luck.
lookig at my auto electrical program (yes i dabble in this as well!) the V6 and V8 are similar looking, similar outputs but different mounting holes/pulleys etc etc. you may be able to fit a V6 one but for the price difference get a V8 one and save the hassel!.. (V6 RRP is $410: V8 RRP is $465 for Bosch units) your local CHCH auto sprkies should be able to get one today for you the dist center in CHCH has them in stock part number 69BXH1231
(also assuming its a VN V8 engine??)
chur
chur
