independent Spring vrs independent Torsion
brakes-shocks-lockers-etc
mytronic
Post by mytronic »
Hi all
Can someone explain the real difference between the two.
As Beam axil is getting harder to find, is there any real difference between Spring and Torsion :?: As I see it body lift is one for the springs, but it is also limitted by the CV arm :?: and bump stops. So my reasoning is that A Zuk is as good as a Pajero say or even a Cherokee :!: :!: or the other way around
WACKO
Pyro
Post by WACKO »
ouch... i can see a can of worms here... :lol:
mytronic
Post by mytronic »
Not game for this one aye 8)
As yet I have not been able to get an intelligent answer over this question.
DaveM
Post by DaveM »
Torsion bars work by twisting action, so would have thought that the coil sprung ifs (Prado etc) would have better articulation perhaps?
What do you mean by body lift is one for the springs?
WACKO
Pyro
Post by WACKO »
personally i think solid axles are better but am still more than happy with my paj, so ill just sit on the fence. :lol:
mytronic
Post by mytronic »
DaveM wrote:Torsion bars work by twisting action, so would have thought that the springs (Prado etc) would have better articulation perhaps?
Yep, I see where I went wrong on that one. Sorry. Was thinking Zuk again with body spacers to get the tires under. My error.
springs torsion
I follow a safari around a lot in my first year 4wd , the torsion did its job but the safari with its coil spring just did it better thats why i brought one and retired the ute
Petemcc
Post by Petemcc »
i have torsion bars in my surf and dad had coils in his independant prado. prart from the prado being newer there didnt seem much diff. except with torsion you dont have to get new front springs to lift. though it does stiffen up a little
springs> torsion
will add with the mazda ute sitting on the flat it has 18mm of travel before bump stops , has a lot of downward travel, so everybig bump hole what ever that force is then applied to the suspension arms and mounts, not the springs taking the load, there is a limit to how long you can hammer something then it fails,
rokhound
Post by rokhound »
The main deal is traction.
With a soild axle, as one wheel is pushed up, it has to affect what the other wheel, (which is attached to the same axle) is doing. So piush 1 wheel up the other wheel will be pushed in the oppisite direction. The more compliant the suspension set up (be it colils or leaves) the better teh traction will be, because at least one wheel will be getting forced down into terra firma.
Ifs (independant front suspension) is exactly as it states. Each wheel is totally independant from the other. Hence if one wheel lifts, it doesn't put any pressure on the opposing wheel, and you can loose all front traction because the one wheel on the ground just doesn't have enough pressure down on it. Standard 4wd,s witrh IFS are pretty difficult to make articulate because of the length of the upper and/or lower arms, Driveshafts to the diff and 2 cv's on each side.
IFS can be made to articulate really well, but you have to start from scratch, and have a track width of a Mack truck. But if you want to really see it working, have a look at some desert racers from the States.
This is an overly simplified explanation of why the soild (beam) axle is the best option, feel free to add on/offer new opinions on this one guys.
SupraLux
Complete Bastard
Post by SupraLux »
A torsion bar is just a straight coil spring... they are different ways of achieving the same thing. The limiting factor is the amount of travel allowed by the arms... which is going to be around the same amount regardless of model... although longer a-arms should equate to more travel... although again a narrower truck will need less travel to provide the same effect... although that will make it less stable (see the sheffield mudplug where pretty much the Suzukis fell over a lot (and H2O but lets not go there :) )... although... although... although...
My advice without getting to scientific?
Buy the truck you like, and SAS it :)
Steve
H2OLOVA
Post by H2OLOVA »
SupraLux wrote:(see the sheffield mudplug where pretty much the Suzukis fell over a lot (and H2O but lets not go there :) )... although... although... although...
Steve
I know i know....... its cause i'm a dick :wink: :oops: :?
rokhound
Post by rokhound »
H2OLOVA wrote:I know i know....... its cause i'm a dick :wink: :oops: :?
Don't be so hard on yourself Richard. You just aim to please the crowd :lol:
H2OLOVA
Post by H2OLOVA »
Just as well i'm not a hunter cause my aim sucks :lol:
albundy
Rolly Polly
Post by albundy »
Totally agree with rokhound on this one. If I fail an obstacle it is usually because of the front end. That's why I want to put a mk/mq patrol front axle with 4.88 diffs. Mind you, if you aren't wanting to do serious shit 4wdrivng all the bloody time 8) ( hey boys) then I would probably not give a damn about the differences between a solid axle and IFS. Just reindex the torsion bars then wind the lift up. You will still get the same spring. Just remember that it is a long peice of steel rod under the truck that will get bashed, I have a slght bend in one from riding over rocks :wink:
Al
DaveM
Re: independent Spring vrs independent Torsion
Post by DaveM »
mytronic wrote:Hi all
I thought we were only comparing between a torsion ifs and coil sprung ifs :?
No comparison really. If you go offroad, go beam axle :twisted:
rokhound
Post by rokhound »
Yeah Dave, I think ur right :oops:
Should have read the original post more thoroughly :oops: :oops:
And you are double right, IFS is IFS
No good for hard arsed shit.
mytronic
Post by mytronic »
Ah
Just as I thought No real difference in the scheme of things
Thanks for the discussion ,things are certainly clearer now.
Just a parting thought.
What happens as all the Beam's die as no one is making new? Or am I wrong?
DaveM
Post by DaveM »
Unfortunately beams are a dying breed,with Defenders and Patrols being still available, but the Patrol's beam days would be numbered too.
As long as there are Steve's out there, you will always have the option of a beam axle, even if it's not from the factory floor :wink:
rokhound
Post by rokhound »
Have to buy a nissan pootrol
I think even 110 landys are or have alreday gone IFS.
Some of the new stuff has fairly good articualtion, (100 series, Rangey etc) But still difficult to alter at a later stage
turoa
Pyro Junior
Post by turoa »
im fairly certain that defenders dont have IFS. They have solid front axles. The new disco has IFS but the series 2 disco didnt. Im not sure about the new rangys but the p38 rangy had a solid axle aswell.
Cloggy_NZ
Texas Chainsaw
Post by Cloggy_NZ »
Going back to the original question about the difference between independent coils versus independent torsion bars....
Some things I can think off:
Unsprung weight versus sprung weight.
Unsprung weight is the weight of the vehicle not supported by the springs, diffs, axles, suspension arms, wheels etc. The less unsprung weight, the more readily the wheels will adapt to irregularities in the terrain (wether on-road or off-road), the easier it is for the dampers to control the suspension and the more comfortable the ride.
In a coil sprung vehicle, half the weight of the coil spring is generally considered to be part of the unsprung weight.
Not so in a torsion bar equiped vehicle. Here the weight of the torsion bar is part of the sprung weight.
Space.
A torsion bar can lie alongside an existing chassis rail and torsion bar suspension as such tends to take up less space than coil springs.
Suspension Travel.
Generally speaking, coil spring will ultimately allow greater suspension travel. Although other factors come into play here as well, length of suspension arms etc. And there are exceptions of course.
Cloggy
zuky
Post by zuky »
I thought patrols we're going independant all round :?:
It's only a matter of time before we're all driving suzuki's they still come factory Beam :twisted:
As for IFS I would put my money on coils. As you can get a longer spring in there so it'll be softer :) SO off road you'd get a better ride. There are some pretty good aftermarket kits around but mostly for coils.
Grab a locker and flex won't matter, cos if you've got a wheel off the ground you'll still have traction :)
