wanting to do a body swap from a ln60 chassis with a ln130 body i semi know how to body swap need information prices and people to do wiring for new body and if there are any hidden costs in this whole process
cheers pete
p.s in in chch
body swap info needed !!!!
Re: body swap info needed !!!!
http://www.offroadexpress.co.nz/Forums/ ... 18&t=12307
The wiring should be pretty easy and wouldn't take an auto sparky long to swap it over. Mine was pretty easy and took a couple of hours but i have a different motor so didn't need to worry about that side of it.
so what leaf set up did you do falcon springs ?? and what did you do for the front and how much dose a auto sparky cost these days and are there any hidden cost you have run into
and what did you do about the steering
I've just got lifted springs but that'll be changing soon most likely. Wouldn't know how much an auto sparky costs, haven't needed one since I'm a sparky myself, and the original steering shaft connected straight up to the new body
awesome so that would be the same for an ln65? i want to put my ln130 on a ln65 chassis
