rear pinion bearing install
ok, I aint a mechanically minded person
but do ya reckon it would be advisable for me to attempt a rear pinion bearing install in my 80
or is it a bit more specialised
and wheres cheapest place to find said bearing
cheers guys
SKID
kbushnz
Re: rear pinion bearing install
Post by kbushnz »
If you are not mechanically minded.....Give it a miss....
Need some tools / bearing press.... Dial gauge...
Not sure who in Welly does them....
yep as Calvin says it'll be a Phil job to set up all the preloads and backlash and shit, still got my one sitting here waiting to take over to him to swap out the C&P one night.
last pinion seal I got came from mana bearings he had them in stock and was pretty cheap, dunno what his bearing prices are like, carrier bearing dont come cheap so pinion bearings probably arent much better?
UBZ
Post by UBZ »
I'd recommend you get a solid pinion spacer fitted at the same time .
IcedJohnno
Trailer Trash
Post by IcedJohnno »
UBZ wrote:I'd recommend you get a solid pinion spacer fitted at the same time .
x 2
mudmike
Post by mudmike »
x 2
x3 it cost new crown wheel and pinion, and all the bearings on the rebuild when the crush sleave moves
Return to “Toyota”
