Diesel or petrol.??
Selling or wanted vehicles.
WRXBOY
Diesel or petrol.??
Post by WRXBOY »
Are petrols any good for offroading? Do they water trOubles?
WRXBOY
Re: Diesel or petrol.??
Post by WRXBOY »
Will they die if water goes up exhaust?
Overkill
Post by Overkill »
WRXBOY wrote:Are petrols any good for offroading? Do they water trOubles?
Sealed properly, petrols are great offroad in water.
Overkill
Post by Overkill »
WRXBOY wrote:Will they die if water goes up exhaust?
Water won't go up into the motor from the exhaust unless you are planning to make a submarine :lol:
But if you are talking about the engine stopping from restricting the exhaust flow by going into water, then you have nothing to worry about, they won't die, just keep burbling along until you are out of the puddle :wink:
farken oath petrols are good but so are diesels, its all horses for courses it depends what sort of driving your doing and what sort of trips you want to do. Petrol or diesels can both die in water if they arent sealed up properly but your going to have better luck in deep water with a properly setup diesel coz theres no electrics, coils, dizzys, plugs etc to die under the water
nup as per the previous post its fine so long as the engine's running and generally ok if the engines stopped but if its sunk in deep enough water and strong enough current it can force water up into an engine that isnt running whether its petrol or diesel
playing in water is a real killer on your truck, maintenence on the mechanical componants (diffs, hubs, wheelbearings, brakes, gearboxes, alternators, starter motors etc) trying to keep water out and removing water is high and silt cuts down seals pretty quick, sunk vehicles are even worce with toasted ECU's, farked wiring looms, rust/corosion from trapped water ingress and hydraulicing engines :x
Sunk Surf Photos Here
WRXBOY
Post by WRXBOY »
Thanks, am looking at a petrol truck, and I just didn't know if they where any good. Thanks for conferming they are good. I think that surf is.....trying to hard to be a submarine lol :lol:
3VILC
Post by 3VILC »
I've got an old petrol hilux..goes mint offroad, idles will idle along like a diesel once in low range..although the old 4Y engine does make peak torque almost as low as a diesel which is good. Havent played in any deep water yet, snorkel is the next project on the list
