the air con stop last week. today i notice the shaft was not spinning at all very fast.
looks like it has a rubber bearing between sharf an pully.
any one know if it's replacable or do i have to replace the whole pully
jono
Air con Pump on the 80 series
Re: Air con Pump on the 80 series
the pully is slipping were the black rubber looks a little over used
which is slipping so much the shaft only spins maybe 1 full turn to 10 of the pully
- mudlva
as it is a magnetic clutch system the pully should be able to be replaced as a seperate unit
Don't worry about it till next summer Jono.
it's more to keep the truck dry pete
wife uses truck every day and once it does start to rain, the truck get wet slowly with having to put the belts on the kid. and archies buggie get wet too from walks.
some shops can get replacement armatures for pumps like that last one i brought for a job at work was about 120 bucks rrp i think..
