front beam axle ques?
skidmark
Post by skidmark »
hi probably a simple question,have searched but didnt find what i was looking for..
basically have a surf that will be getting a 1uz auto and sas.gathering all big parts before i start.have a v6 surf and 1uz. surf is currently 4.56 ratio (g255 feel free to corect me if im wrong?) but so far ive seen prado and landcruiseer seem to be 4.1/4.3/4.8..is there a diff head that transfers to thoose diffs? or would i be beter to change rear diff ratio.
cheers or if any one has spear diff that is no longer requiered pm me..haha
Smurf
Re: front beam axle ques?
Post by Smurf »
The prado diffs are hi pinion fronts, so easiest option is to swap out your rear to same ratio, usually 4.8. But yeah, there are hilux/surf diff heads that match the prado/cruiser ratios.
If you use a hilux front diff then you have the option of running amost any available ratio 4.1, 4.3, 4.5, 4.8.
really comes down to gearing and tyre size. You may need a certain ratio to keep your final drive ratio correct.
skidmark
Post by skidmark »
Was planning on at least 33s but preferably 35s....so might just keep a eye out for 4.8s in that case.
Return to “Toyota”
