Hey guys, when i turn the key to on the green boost light comes on but when i'm driving it doesn't seem to turn on when i can hear the turbo working, does any one know how to get it going?
also i noticed that the plug on the air intake pipe was unplugged so i plugged in in to see what happens but the car stalls as soon as it starts
Thanks
Sam
Surf 2LT Boost light not working
1989 Surf ln130 2lt
31 maxxis buckshots
2 inch suspension lift
31 maxxis buckshots
Re: Surf 2LT Boost light not working
got a pic of the plug ?
and what model surf do you have ?
either unplugged, broken,no power or the air line to it has a hole, pulled off somewhere meaning there is no air to pressure the switch to tell it you are under boost.. check the lines and plug/ power to plug
hey its a 1989 ln130 heres a pic i found on the internet, i was to dark to take the photo, its the one at the bottom
1989 Surf ln130 2lt
31 maxxis buckshots
31 maxxis buckshots
sounds like boost sensor wasn't plugged in due to it being faulty by the sounds of it.
it should be the D-turbo model ie not efi. the boost sensor runs the lights and egr setup.
i would leave the boost sensor unplugged and go fit a boost gauge.
will i still be getting maximum boost out of it with it unpluged?
1989 Surf ln130 2lt
31 maxxis buckshots
31 maxxis buckshots
should be. fitting a boost gauge will tell you for sure.
i would also block off the egr and disable the egr butterfly.
what does blocking off the egr do?
1989 Surf ln130 2lt
31 maxxis buckshots
31 maxxis buckshots
