Wanted 4.88 Gears for Nissan C200 diff from early D21
lax2wlg
Post by lax2wlg »
Hi guys
I'm looking for a a 4.88 ratio ring & pinion for the C200 differential, as fitted to the rear of 1987-1990 NON turbo diesel & 4-cyl petrol Terrano/Navara 4x4 (transaxle code CA48).
It's the Salisbury style differential with removeable from cover, also used in the front of the MK patrol. Attached is a photo for identification.
Reason I need this is I am upgrading the front differential in my diesel Terry to an R200 from a V6 in order to fit an ARB locker. Only problem is my current rear gearing is 4.88, and the R200 is only available in 4.3 and 4.6 ratios. Luckily however, the ring and pinion gears are interchangeable between the C200 and R200 diffs!
Please PM me if you can help, once again, ring & pinion stamped 4.88 from a C200 rear diff. CA48 transaxle code, 1987-1990ish D21.
Thanks very much,
Josh
sibainmud
Re: Wanted 4.88 Gears for Nissan C200 diff from early D21
Post by sibainmud »
lax2wlg
Post by lax2wlg »
Bump
