rear springs
pajeroboy
rear springs
Post by pajeroboy »
does anyone no what the ARB or EFS rear springs fitted into a 01 swb soft top pajero are like?looking at getting new springs,have hurd that they can make the ride very hard,what would be better to have a fixed spring rate or progessive rate?
33" muddies, 50mm body lift, ball joint flip, quick release front sway bar,40mm lifted rear dobi springs and new shocks,custom sill body armor,custom front bar.
SAM
NJV6
Post by NJV6 »
HI, it depends weather you want to lift it or make it handle a load better. To just lift it i'd try adn get some same diameter (rate) coils but longer. To lift it by putting heavy duty springs in will often result in a firmer ride.
I have never tried progressives in a Paj - Worked quite well in the old Rangie but they always ride nice 8)
WACKO
Pyro
Post by WACKO »
01 jtop? if thats the right year, get us some pics! did you mean 91? i have a 93 jtop and i put raised lwb king springs in it. lifted it nicely and i dont find the ride to harsh either. if it makes a differance to you, i have the adjustable shocks and ride height in mine, so its in hard on the road and soft offroad.
SMOKEY
Post by SMOKEY »
Give Murray a ring he's the Pajero guru in Christchurch, has all the bits and pieces you need.3474901 or0272517055.
FITZY.
4WDbits
Post by 4WDbits »
Springs are designed for a certain amount of load, hard springs for more load. Choose the coils that best match what you use the vehicle for. A quick comparison can be done between current coils and new aftermarket ones using the number of coils and wire size. Smaller the wire diameter and more coils makes for a softer coil.
The specs for Pajero EFS coils can be found at http://www.4wdbits.co.nz/ProductsListPrice.aspx?CategoryID=45
pajeroboy
Post by pajeroboy »
hey thanks for the help,ohh and yeah it is a 91 not 01 my bad
SAM
Return to “Mitsubishi”
