surf dash lights wont go off
mayhem1982
Post by mayhem1982 »
have just done crank seal and cambelt etc on my ln130 surf with a 2lte in it.
i have got it back together and it is starting/running fine.
only problem is all the dash lights stay on and that annoying beep stays on.
anyone got any ideas?
jonossiksilvia
Re: surf dash lights wont go off
Post by jonossiksilvia »
did you touch the alternator at all? belt to alternator tight? id be looking at anything electrical u touched while doing the work
mayhem1982
i only loosened alt to get the belts off, then tightened belts again to put back together
jonossiksilvia
mate had his alternator belt slipping everytime he went in water and would do the same thing. ln130 also. problem went away once i tightened his belt.
perhaps its one of those moments where you touch something and something else fails at same time causing 1 hell of a headache
mayhem1982
yeah, think i might have figured out my deep cycle battey might be flat.
have both batterys on charge over night and will check again in the morning.
i think it might be time to purchase a multi-meter
mayhem1982
so i had another play with it tonight, starts and runs ok still, alt is working and charging both batteries so my next guess is ignition barrel? its doing my head in :x
vvilly
Post by vvilly »
when my alternator brushes were on way out it put all my dash lights up
have ya looked at them
mayhem1982
alternator was fully rebuilt 6 months ago so hopefully its not that.
might be easier to just take it back and get them to check it, as i have no idea how to check bruches etc
mayhem1982
turns out it is the regulator in the alternator, just out of warrenty too :cry:
Return to “Toyota”
