hilux suspenson advice
KIWI_TERRANO
Post by KIWI_TERRANO »
Gday all
So my truck failed warrent on front spring as ones a sad face ha
So its time to pull the gourse out of my pocket finially and buy a lift, I want to lift it enough to run 33s and have it pretty soft as it never carrys loads just dogs.
What height lift do people recomend?
And what brand do people reckomend?
I was looking at Ironman
Thanks all
imsohi
Re: hilux suspenson advice
Post by imsohi »
KIWI_TERRANO wrote:What height lift do people recomend?
Are you doing front and rear springs? or looking at putting longer shackells in the back.
to fit 33's i would recommend a 2'' lift minimum and i would go for Old Man Emu as they seem to take more punishment and are alot softer spring.
KIWI_TERRANO
I be getting full kit,springs shocks bushes etc
bob_or_jim
Post by bob_or_jim »
Second that on the OME, PM SuV6rf. He put a standard Ome kit in his and its nice and soft with plenty of flex.
KIWI_TERRANO
looks like il be ringing up to get a old man emu then,
Will 2 be enough or should I go 3inch?
First time lifting a leaf sprung truck so bit of a noob
would love to coil convert the front but cant afford to
ToyRover
Post by ToyRover »
my efs ones are pritty soft i went 3 inch front two inch rears front still can flex and touch bump stops rears are normal, could just put shackles on rear might make it softer and flex better
KIWI_TERRANO
what efs cost?
If you have certain kit in you truck canyou please post a ruff price save me ringing heaps of different supplierstomorrow, thanks all
philux
Post by philux »
4wdbits on here sells the efs range, had them in my old ln106 hilux, front was real good but I had too stiffer springs in the back, bit of mucking about you could get it better
elvis
Post by elvis »
hey when i went down this track i talked to a few people about options as most guys i no running a 2 inch lift and 33s still get a little rubbing. I ended up getting tom to ruf the front and I put a 2 inch lift kit in the rear from bellamy and east(they do a kit in the rear for 4wding which is pretty soft they flexed alright and were nice and soft on the road ive since had to get another spring added for towing the boat they are a bit to hard for my liking now and not so good at flexing), i remember rick from 4wd accessories telling me you can panel beat the guards so 33s dont rub.lift kits cost a bit of money so id be asking everyone i no if i could take there truck for a ride to compare stay away from maxi trax they are hard as hell and my mate had 32s on his which rubbed quite bad your more then welcome to take my ute for a test drive if you want.
cheers troy
Trundle
Post by Trundle »
Is it an ln65 ?
how serious are you going to get off roading , ?
do you use it on the road often?
What is your budget ?
KIWI_TERRANO
Trundle wrote:Is it an ln65 ?
I use the truck for tahr hunting in winter so need flex and ground clerance as I go to some nuggety places and then in summer it tows the odd boatand thats about it, decks usually empty or got dogs in so much weight up back. Use it on road a bit but mainly shingel (about 15km) to get to town so wont it to ride pretty smove, andbudget well that depends on the kit and how good it will be I guess haha
KIWI_TERRANO
Thanks for all the help, I rung Rick today in at 4wd accerioes and with his knowledge and time he pointed me towards Ironman stage one kit bit more expensive than Old man emu but the kit works out better, reackons it will be the best fit for my needs after explaining everything I do and explain I plan on running the 33x12.5 cooper st I have sitting in my garage.
Will post before and after pictures when I get it in :D
Trundle
Post by Trundle »
I personally am a dealer for tough dogg , however if you want a cheap kit iron man is ok ,
The reason i asked if you use it for multiple purposes is that i would strongly suggest getting adjustable ones so if you dont like how it rides you can actually do something about it ,
I personally use 45mm bore 9 way adjustable tough dog;s but if you were on more of a budget the rancho rs9000xl is a good all round shock ,
You may also want to consider extending your diff breathers ,and possibly running a castor wedge if you find it tracks after the lift ,
The downsides to adjustables is your looking at 980 to 1500 a set instead of 600 ,
At the same time it is better than buying the 600 dollar ones , selling them for 200 because your not happy and still having to fork out for the 1k plus anyhow ,
KIWI_TERRANO
Yer I have had adjustable before but I got sick of having to tune them and breaking knobs off, From what I researched and been told old man emu springs are pretty much same as Ironman and the shocks are better for what I do then other kits so Im happy with that. Not to bother if it rides a wee bit hard it will never ride like my old sas surf!
Truck already has diff breathers mate first thing I did when I brought it as I often ford rivers to get around the farm.
Macca
Post by Macca »
Hi, just a note, I assume you are aware that stewarts can am dealers in washdyke do ironman. havent seen it advertised but have got stuff for work utes through them. Ben is very good to deal with so would recomend him
KIWI_TERRANO
Macca wrote:Hi, just a note, I assume you are aware that stewarts can am dealers in washdyke do ironman. havent seen it advertised but have got stuff for work utes through them. Ben is very good to deal with so would recomend him
Yes have seen that but rick is a good man and I am to loyal to his services
Macca
Post by Macca »
yup fair enough cant argue with that, have only heard good things about him,
truckingood
Post by truckingood »
i just bought a full set of rancho rs5000's for my wagon, i looked around for about two weeks mate talking to this person and that rung 6 different suppliers and got prices and advice on what shock, what i got was that dosent really matter what colour and name is on the things they do the same thing :!: and there farking expensive in this country
Return to “Toyota”
