my 80 will not come out of park unless you push the red shift unlock button. will move from L up thru the gears into park. have tried adjusting the slider on trans underneath but still no go. any help would be great.
cheers jono
80 series not coming out of park
- firestonecruiser
Re: 80 series not coming out of park
If its anything like a surf it'll be part of the brake light circuit check that you have brake lights, possibly just a blown fuse?
Sometimes it's caused by damage to trailer plugs blowing the fuses.
There will be a problem with the shift interlock system..Here is a link to how the toyota systems work...
http://www.autoshop101.com/forms/h18.pdf
Check the brake light fuse. It will be that. I have this problem on a semi regular basis due to the amount of different dodgy trailers I tow. I found the biggest contributor on the truck to the problem was the snap lock splice terminals that the trailer plug wiring had been spliced into the main loom of the LC. I removed these, soldered and heat shrunk the joints and this helped a lot.
Jase.
Jase.
- firestonecruiser
have just checked truck. still have brake lights going so no fuse is blown. checked tail light fuses and all ok but still wont come out of park. dont really like pulling thngs apart that i dont know nothing about. is there another fuse i should be looking for.
cheers jono
cheers jono
I had a simaler problem with mine. When trying to work out the problem i noticed the dome light fuse was blown. I replaced it and the problem went away. After checking the circuit diagram i couldn't work out why this fixed the problem, but it did, and the problem never came back.
Tony.
has the brake pedal switch failed, or take the covers off from around the leaver ass and check for power at the soliond as that may have failed also? have some wires come off at the foot pedal switch?
- firestonecruiser
Mudde1 wrote:I had a simaler problem with mine. When trying to work out the problem i noticed the dome light fuse was blown. I replaced it and the problem went away. After checking the circuit diagram i couldn't work out why this fixed the problem, but it did, and the problem never came back.
what do u mean by dome light. excuse my ignorance.
- firestonecruiser
pressy wrote:has the brake pedal switch failed, or take the covers off from around the leaver ass and check for power at the soliond as that may have failed also? have some wires come off at the foot pedal switch?
will try to locate foot pedal switch tmoz n check the wires. my problem with removing covers from gear shifter is i have to remove all my after market gauges aswell which is goin to be a pain in the ass. normally when foot pedal is depressed u hear a click and lever moves but now have no click.
firestonecruiser wrote:pressy wrote:has the brake pedal switch failed, or take the covers off from around the leaver ass and check for power at the soliond as that may have failed also? have some wires come off at the foot pedal switch?
the surround should just lift up from round the lever and the you should be sble to see in there. that is just off the top of my head, been a long time since i had mine out, and i think there is a screw that you can undo on the handle and 4 screws from around the lever with the P,R,N,D, and so on and that will lift free and will have the light wires under it so be careful.
