Supliers for new C&P
imsohi
Post by imsohi »
Hi all
looking for a good supplier for toyota crown wheel and pinions both std and aftermarket (chromolly) types anyone have any good guys they use?? would prefer In NZ but will import from AUS/USA if needed.
Cheers leigh
suzolla
Re: Supliers for new C&P
Post by suzolla »
Presume you are looking for 8" low pinion, what ratio are you after.
Tim
imsohi
Post by imsohi »
suzolla wrote:Presume you are looking for 8" low pinion, what ratio are you after.
Tim
Hey Tim
i will be looking for 8" low pinion (hilux)
2@4.3
1@4.5
8" high pinion (Chromolly) Prado
1@4.8
lexlux
Post by lexlux »
andrew 021 991241 i just got a cromoly high pinion of him , he has eveything in stock .
IcedJohnno
Trailer Trash
Post by IcedJohnno »
For standard type CW & P's try South Island Bearing Distributors in Chch. They have a good range, from memory.
Ph 03 377 3222
94 Kingsley St, Waltham.
They are on the SE corner of Brisbane & Kingsley Streets
hosehustler
Post by hosehustler »
If you decide to import some yourself I found these guys helpful and happy to ship to NZ
http://eastcoastgearsupply.com/c-61626- ... inion.html
I hate signatures
Return to “Toyota”
